Well my PB’s chemical guy saw my truck home today and stopped by, first time I met him. He made a call and will install automation and do pool school Friday. PB thought it was already done.
Fill water is notoriously high in CH in this area. Think it was 275 out of the tap. Just don’t want my water eating my plaster ( in my mind the plaster is still fresh and softer)Your CH is fine. Did you test your fill water for CH? Your CH will rise over time as your water accumulates it.
CYA test is not that precise. +/-10 is to be expected.
Test results will for CYA, CH, salt drift over time.
CYA testing-a test I did not like BUT have found a way that works for me. Here we go:
-remember you can do and re-do the test just by pouring the solution back and forth to get an average
-GLANCE for the dot only. Do NOT look for it. Just glance in and then look away.
-Pour to the first line (100) glance in. If you see the dot pour to the next line, GLANCE in, keep going until you don't see the dot when you GLANCE in. Call it at that number.
Rain and adding water will dilute your CYA and salt. In FL I almost always have to add some CYA in the Spring and again during the summer if we have a lot of rain. I just get the kind I can find at Lowes or Home Depot.
I hope this helps!
Kim![]()
