Alright, posted previously about getting some resources to educate myself, now looking to sign contract soon. i've had them put in details like variable speed pump and SWCG as well as cartridge filter. Number skimmers/returns/drains seems ok based on what I've read.
Here are the highlights, hoping someone can glance over it and give ideas. cost is $96,000 : / They are saying pool prices are up almost 20% from a year ago.
Dimensions: Swimming Pool
Width ~16’ Length ~28’
Shape: Rectangular
Area: 448 sq ft
Depth: 3 1⁄2’ in shallow end to 6’ in deep end
Dimensions: Spa
Shape: Rectangular – 7’ x 7’ Inside Dimensions
Area: ~ 49 sq ft
Depth: 3’ Raised 18”. Natural Stone veneer to be chosen. 24” wide spill-way.
Spa to be equipped with (8) Jets and winter disconnect.
Excavation: Pool/spa to be dug with bobcat, majority of dirt to hauled off site.
Steel Reinforcing: Per engineers supplied specs #3/#4’s rebar. 12”/6” per engineers’
recommendation.
Gunite: To be pneumatically applied using a ratio of one part cement to three and one half parts
sand, mixed dry on site, with hydration occurring at nozzle.
Electrical:
1 - Timer for pool cleaner and pool filter
1 – 2hp Pool/Spa Filtration Pump – Variable Speed Pump
1 – 3/4hp Automatic Pool Cleaner Pump
1 – Salt Sanitizing System – Zodiac Nature 2 Fusion Soft Cell Kit
4 – LED “Nicheless” Colored Pool Lights
1- LED “Nicheless” Colored Light Over Sun Shelf Area
**$4,000.00 allowance for electric run/connections, anything extra will be additional
Plumbing:
All plumbing to be pressure tested with air/water
2 – Independent plumbed surface skimmers
4 – Pool wall returns
1 – Automatic pool cleaner line
2 – Anti entrapment pool main drains
Heater: 400,000 BTU Gas Heater with required gas Hookup from existing residence meter to pool
equipment.
Fuel Source: Natural Gas. Assumes meter is/can be upgraded, if required, adequate for pool heater.
**$2,000.00 allowance for gas run, anything extra will be additional
Filtration: One Jandy 60 sq ft Cartridge Filter to meet the filtration requirements of the
swimming pool/spa.
Coping: 16” x 24 x 2” bull-nosed travertine- Walnut or Beige/Ivory color, or similarly priced coping,
per client selection.
Tile: Decorative glass frost proof tile at pool waterline and matching/similar trim tile on steps,
tanning ledge, and benches, per client selection.
Shallow End Tanning Shelf & Steps: Shallow End Sunshelf with umbrella sleeve and Shallow end
steps, (2) 5’ deep end benches, as per design.
Bench: Two 5ft benches in deep ends of pool.
Water Purification: Salt Sanitizing System.
Interior Finish: Quartz Pool Finish – Color To Be Selected.
Water Fill: To be trucked in. Included in contract.
Winter safety covers: Mesh safety with grommets included pool. Spa Cover to be hard foam cover
that can be locked down in winter months when spa is not in use. Color TBD.
Miscellaneous Items for Swimming Pool Included:
Chemical testing kit
2 telescopic poles, 8’-16’
Leaf net
Wall brush
Vacuum head and hose
Completion of Pool and Spa:
Indoctrination shall be conducted after 30 day cure period for plaster.
Owner’s manual shall be presented.
Construction site shall be cleaned of debris and leftover materials.
All disturbed areas to be treated with rough grading (no raking or topsoil), seed and straw.
Shape: Rectangular
Area: 448 sq ft
Dimensions: Spa
Area: ~ 49 sq ft
recommendation.
Electrical:
Plumbing:
equipment.
swimming pool/spa.
Leaf net
Wall brush
