Omg Kim. I have seen some designed gas tanks but that is pretty cute! Not sure if a rented tank can be painted lol
So in other news, no one seems to know how the heater got installed too close to the house but now EVERYTHING has to come off and the plumbers have to repipe everything at the equipment pad to fix the placement. Oy!
Next, today a guy came out and busted out half of the concrete on the existing back patio. Of course, 2 separate torrential down pours blew in and turned it into a muddy mess. Grade looks good but there is one small issue....
The other part of the back patio concrete is still in place as it was a monolithic pour, meaning part of the foundation. They also made it so it is graded as well so there is more space between the concrete and the bottom of the trim/siding. But as you move back towards the house, the space becomes less and less to move the water away from the house. In the far back corner where the trim is, there is barely 1.5" of space and the trim is right at siding height. Some other areas by the doors has trim that extends beyond the siding so technically the trim can be cut to make room but the far back areas have no wiggle room.
When we had all of the pool companies out for consults when all this started, one of my main concerns was the space between the concrete and the siding as it is misleading if you only judge it by the space closest to the outer edge of concrete/dirt. It looks like no issue by the outer edge bc of the grade. Everyone said no problem! Ok....
So when we originally were doing concrete pavers, the remodeling pavers were an inch thick and I was still concerned about them fitting. Well then the whole paver issue came up and we looked at travertine. When I saw they were 1.25", I specifically asked PB if that was an issue and brought up that if it was too tight ALL of the concrete would need to be removed (which since we brought this concern up multiple times and were always told no problem, I don't think we should have to pay for that as we asked and were ready to have it included in the quote. The concrete removal due to grade issues is not our cost either as PB has already confirmed due to the pool being shot at the wrong height). Again, told no problem so we ordered the travertine.
The construction manager stopped by today and I showed him the areas of concern and how some areas could be trimmed but some couldn't. He saw what I was talking about so is going to talk to PB about that. The deck prep is supposed to be done tomorrow am (late as termite spraying was supposed to be at 10am and now has to be moved to the afternoon) but not sure what they are going to do with this "new" issue esp bc you cant just jack hammer this concrete as it could crack beyond where they are working into the remaining foundation but not sure how to cut the concrete bc the house is in the way of the concrete....
I am fairly certain plumbers are coming tomorrow to fix the heater issue, hoping the coping gets finished soon, deck crew will be here but again, need to iron that out, bug guy should be here in afternoon, still waiting to hear about the gas people. Oh hubby and construction manager did get the conduit trenches dug for the gas lines. And hubby cleared everything off the patio and pressure washed thr back patio, house, windows, and basically the entire back of the house as all the rain and dirt makes mud that has splashed up all over the house.
I am so anxious to see the deck laid out! I hope they can get this figured out and quickly. Every time we take a step forward, something else pops up.
Also, I thought I had mentioned this on here but cant find it. We had picked out CL Industries Sunstone Blue Pearl for plaster. We had picked it after seeing it and Aqua Pearl in completed pools. We want a rich, vibrant, saturated blue. We had picked this color when we had the darker deck in the sierra color. Well now that we have silver travertine, I am concerned the plaster color is not going to pop like we want. I contacted CL Industries via FB messenger to discuss their colors bc not every color is shown in an actual pool and the ones that are don't always have the best angle or lighting to get an accurate idea or the pics looked edited.
CL Industries said that Blue Pearl is a lighter blue and is very pretty but not what they would call a rich, vibrant blue. They said the St Lucia Pearl would give the vibrant rich blue. Of course, that was the one we had first inquired about back in Jan/Feb and shocker, it is an upgrade as apparently the colors cost different prices even in the same line (like this Pearl line) bc the darker ones have more pigment in the Portland cement. Is this common? No glass, just pebbles. I have contacted the PB to see if it is truly an upgrade and if it is, how much. Also still waiting on abalone shell cost for hand casting. CL Industries confirmed that they do not void the warranty and they do sell them to distributors.
Oh, and I just remembered hubby had mentioned wanting to use a different material on the actual spill way instead of just silver travertine. I am on the fence about this as the silver travertine does has unique features piece by piece, we have the ledger stone, and the glass tile. Is it too much to throw something else in with a different color and material? Or it would be a nice pop? I am so visual so I have a hard time seeing it without physically touching and seeing.
Here is the only pic I have for now. The removed section of concrete and mud after the first down pour today
