Hi everyone! I'm a longtime lurker who is about to sign a contract on a new build in Houston and wanted to get any last opinions on our build. I've already gone back and forth on a few things to get here using the knowledge I've gained from all the smart folks here, including getting a credit from the pressure side cleaner and buying my own robot.
Pool General Specifications:
✓ Pool depth 3.6’ to 6’
✓ Pool dimension 27’x23’ water area, 27’x25’construction. Straight Lines Design.
✓ Pool Perimeter 100 Ln Ft
✓ Tanning ledge with 12” of water and 2 Bubblers. One step on the tanning ledge.
✓ Raised back wall 12” with two sheer descent waterfalls 24”
✓ Rebar #3 on wall and bottom, rebar #4 in the bond beam. 8” tied spacing
✓ Gunite from South Bay Gunite, the Best Gunite company in Houston, 8” Thickness on walls,
floor and coves, 12” Thickness in the bond beam.
✓ 2 Skimmers, 6 Pool returns. • All plumbing lines are schedule 40 PVC and run separate for
skimmers and main drains. 4 VGB Compliant main drains
✓ Electrical 360 ground bonding and GFCI breaker
✓ Two Pentair Intellibrite LED Color pool lights, one spa Intellibrite LED color light.
✓ Two Glowbrite Color lights with low voltage transformer on the tanning ledge.
✓ Travertine, Marble or Limestone Coping.
✓ Any tile up to $12 Sq ft included on base price
✓ Mini Pebble Plaster any color.
✓ New Cool Deck 833 Sq ft including existing covered area.
✓ Auto fill water level.
✓ Pentair Intellicenter, system with automation and remote control.
✓ Heated pool.
✓ Glacier Chiller for 20,000 gallons.
✓ Outdoor shower installation close to the corner near the tanning ledge.
✓ Four umbrella holders included.
✓ In pool bench along garage side and back side of the pool.
Pool Decking and Drainage:
✓ New Cool Deck 833 Sq ft. Any extra Sq ft of Spray Deck $9
✓ Adding same pool deck finish to existing covered area.
✓ 4” pipe running to the street with pop-up. Overflow line included and tied into deck drainage.
Equipment: (all Pentair equipment with 3 years’ warranty from the factory)
✓ Filter Pentair 520 Sq. ft Clean and Clear Cartridge
✓ Main Pump: Pentair Intelliflo 3HP VSP
✓ Two Pentair Intellibrite Color LED pool lights, one spa Intellibrite Color LED light.
✓ All valves Pentair.
✓ Salt System Pentair IC-40
✓ Heater Pentair Master Temp 400,000 BTU
✓ Blower: Silencer 2HP Spa Details: (addition)
✓ Spa 6’x9’ rectangular, inside dimensions. Leveled Spa. Open Spillway. One LED Color light.
Payments Details:
✓ Payment #1 (Excavation, Steel, Plumbing 1, Gunite)
✓ Payment #2 (Plumbing 2, Electric, Equipment installation, Coping 1, Tile1)
✓ Payment #3 (Coping 2, tile 2, deck)
✓ Payment #4 (Plaster and clean up)
Pool 100’ perimeter, 500 Sq ft of deck and equipment cost: $40,000
Additions and upgrades cost:
• Spa 6’x9’ $7,000
• Pentair Heater 400,000 BTU with installation $3,000
• Adding 333 Sq ft of cool deck extra. $3,000
• Mini Pebble Plaster any color Pool/Spa $3,000
• Two Pentair Intellibrite LED Color pool lights, one spa Intellibrite LED color light. $1,500
• Two Glowbrite Color lights with low voltage transformer. $1,000 ($500 each)
• Pentair Intellicenter, system with automation and remote control. $2,000
• Salt System IC-40 $900
• Pentair Intelliflo 3HP Variable Speed Pump Upgrade $500
• City of Houston Permits $1,000.
• Pressure Cleaner with Booster Pump credit -$1,300
• In pool bench along garage side 19’ and back side of the pool 23’ $1,200
• Glacier Chiller for 20,000 gallons with installation. $2,600
Total Cost if doing all the upgrades and additions: $65,400
Also Included:
1. Electrical subpanel if need it.
2. Startup chemicals.
3. Pool training on how to operate system.
Warranties:
• 3-year Blanket Pool Warranty. This warranty covers every detail of the construction.
• Pool equipment 3 years warranty from Pentair.
• Plaster warranty 10 years from the brand.
• Will repair any damage to the property from the construction process.
• Lifetime warranty on the shell of the pool.
✓ Heated pool.
Payments Details:
• Spa 6’x9’ $7,000
Also Included:
Warranties:
