So I was just wondering.............Since you started this slam how many gallons of chlorine have you added? At what cost has this been?
skeeter
skeeter
skeeter
I'm no expert, but I would wait until after slam is over to add anything extra. The metal stuff is most likely a sequestering agent that binds to the metal to keep them dissolved in the water to prevent stains. It looks like an ascorbic treatment would be next on the list after the slam to remove the iron stains, then you would add the metal stuff to keep them dissolved.
From the pictures, It looked to me to be iron stains. However I'm not an expert.
Here is what I was talking about.
http://www.troublefreepool.com/content/137-metals-in-the-water-and-metal-stains
http://www.troublefreepool.com/threads/2129-Ascorbic-Treatment-to-rid-Pool-of-metal-stains
Sent from my iPad using Tapatalk
My pool was a swamp when my pump went out for about a month. I finally got the pump fixed but decided it would be easier just to drain and refill the pool.
It cost...
pump rental to drain pool.................................$20
water bill to refill (approx)water is cheap here....$50
conditioner.....................................................$70
muratic acid, 1 gal..........................................$6
chlorine, 2 gal................................................$8
Calcium+......................................................$40
Total.............................................................$194
one day to drain while washing algae of walls, one day to fill and add chems.
Guess mine cost alittle more, but not much. Guess the deciding factor may be the price of water.
skeeter
OCLT test results:
Evening:
FC: 11.5
Cc: .5
Morning:
FC: 10.5
Cc: .5
I think I passed!?
How does the water look?
If you have different electric prices at different times, run it when it's cheaper.
2nd OCLT Test:
Eveing Reading:
FC: 12.5
CC: .5
Morning Reading:
FC: 12
CC: .5
Opinion Needed: When is the best time to have the pump running or turned off? Should I run it during the day while it's sunny out, or in the evening? My head is telling me that I should run it during the day and turn it off at night as FC is used up during the day. Expert needed!![]()
