@mas985
Holyyyyy, you are holy man! (A bit drunk after friday's night meal ... we have those... some jewish customs)
I have to have some special equipment which I don't for this whole pressure testing thing so ... I'll have to test my luck on that I guess...
What do you need for testing anyway? Maybe I can rent a compressor for air, plug my just using a pipe with a cap, although - just shoving it inside the jet and placing and end cap on it doesnt seems enough, and if I glue it then... What?!
BTW, what is a "cap valve"? Like a ball valve connected to nothing?
THanks man... now I can sleep good at night
EDIT>>>
OK, So you say we should pressure test it - then I'll test it Master!
At first I thought it's too difficult to achieve but now I don't really see why shouldn't I pressure test it... I'll finish up my jet plumbing tomorrow (most likely), connect everything including the manifold and all, put end cups on air pipes and buy some threaded plugs that fits the jets (hopefully I can find such) connect it all and then use this youtube view instruction to do the test:
I'll rent a compressor for a day, shouldn't be too expensive...
How much pressure should I test the system on? 10, 20, 30 psi?
I'm scared my jet bodies will explode
I'll probably put an update on tomorrow asking more questions etc
EDIT 2 >>>
Well I've accomplished to get 2 fittings to seal the jets (only 2 instead of 8, they don't have it around in the stores)
Now... I can do a pressure test using these 2 fittings and test the piping for each set of jets (they are in 2s anyways), but then I have to rely on the ball valves to seal the other 6 while testing...
Are the ball valves air tight? Will that test worth anything?
Thanks man.
