- May 3, 2007
- 18,073
- Plaster
- Hayward Aqua Rite (T-15)
That isn't really telling me anything. Exactly what are you looking at in the picture where you can tell which is which. Having water on the bottom is NOT sufficient. Only one of the two ports is for water and the other for air. You cannot swap these even if you keep water on the bottom. Do you have a link to the manual and/or pictures of the manual?@mas985
Well... I've looked at the pre concrete pictures I've sent you and looked at the manual of the jets and it seems like water is water and air is air, water on bottom!
You can't flush the plumbing with only one nozzle removed. ALL must be removed at the same time.I've tried removing the nozzles from 1 jet and ran the pump... Just water out the air pipe... Could it be that the air pipe should be higher above water level? But how come it doesnt suck in the water from the air pipe?
No, the venturi will not work without the nozzles. Removing the nozzles was just to help clear the lines.Could it be something with the nozzles? Maybe a certain way to fit them? They have this plastic clips... Maybe it should be removed?
The venturi should work even without the nozzles inserted? Cause it doesnt...
As I posted before, the venturis do not work without the nozzles. The nozzles create the suction to draw in the air. Without the nozzles, the water will travel up the air tubes.As you can see if I start the blower after the jets nothing works... jets are stronger... water just pushes the air and climbs back...
However, these "tests" are without the nozzles...
That is definitely a possibility. They may not be producing enough suction via the venturi action. This is why I suggested taking some measurements on the pump, suction & pressure WITH nozzles, so that we can determine the actual flow rate going to all the jets. If the flow rate is ok, then it must be something with the nozzles.Maybe nozzles were not placed correctly?
With the nozzle removed, just measure it.I don't know how to check the smallest diameter, it's not written anywhere...
You shouldn't need to cut anything. Most pumps have 1/4" drain plugs that gauges can fit directly into. Can you post a link to the jet pump you used?The pump is not connected to anything but the jets so it's sucking and pushing right-away... it's all glued so I have to cut it If I want to add pressure gauges...
