@mas985 Whaaaaa-t?!?
Holly cracker! Dude what are the 'normal' avarage jets you get in a standard hot tub?
Eg:
"Air-jets" is what is mentioned there...
This is why air bubblers are normally used on floors and seats which is why I brought that up.
We'll thank GOD you did that... better late then never aeehhh
I don't want to pierce people with water... Just have some bubbles and spraying water
I just hope the setup is the same cause changing the plan again and again kinda getting 'ooollldddd' ...
I'll start reading on Google about air-jets vs massage jets...
Edit:
I think I was going for air jets all the time and now im all planned for water jets... I'll start reading about them changes to make at least some of my jets 'normal' for the kids and everybody's sake...
I was going for the hydrojets because I couldn't realize which plastics do you get anyways... Was looking for about a week for 'spa jets' and then I saw in some you tube vids that they are using these hayward air jets... So... The whole which 'plastic' does what thing is kind of confusing!
2nd edit:
Grrr more planning and changes! Wife will kill me... I said it'll take a month or so... Looks like it wont be ready at all this season this way...
They are much more gentle and the surface is very smooth. Better to sit and stand on.
So basically, the two bottom ones should become bubblers - how do you do that?!
Which 'jets' plastics do you get and what do you run into them?! Do I need a bigger blower?
Can you please please please please and one more
PLEASE post an example link / image of one of those or at least an exact full name to look up in google?
(What did I get myself into?!?
Now about them hydrojets... I need to have a way to 'slow' them down for normal sensation / kids play...
Now I'm set for 7*15GPM jets (105 total GPM).
- Removing 2 buttom hydrojet ones gets me to 5*20GPM.
- Adding 10 more jets and get a 3 per sit triangle configuration
-> When all valves are open you get a mild breezy jet of 7GPM and when you want the hydrojets you just close the valves on some of the jets leaving the basic 5 jets on 'always open' mode for safety - not having someone close all jets and blowing the pump or something else...
What do you say??? Does it make any sense?
3rd edit:
BTW how do you get a 'handle' to control the jets valves? I mean like one you can place next to the sitting area which is accessible...
Is it a ball valve situated in the jet's tube directly connected to handle above?
How do you maintain such a thing?!
I guess I can jet eyeball fittings with a turn to close setup and use that to manually adjust the pressure on each of the 'extra' jets...
4th edit:
Well... my previous 'pool' was an Intex one, it came with a 4.5m3/h pump and that went via a filter+heater and then returned to the pool (straight line) and the return inlet was OK, even a bit weaker then I want to have... now, 4.5m3/H even if it lost a lot of pressure along the way the heater's max flow was 3.2m3/H... I gather I'd have around 3 maybe 2.8 m3/H coming from that return... (right?!)
so that's around 12GPM... SO the 15GPM we have right now shouldn't be that 'Hard' ... maybe I'll just add extra 2 jets instead of the bottom ones since these are going to be bubblers... that way we keep it on 15GPM and it should be OK I hope...
SO which plastics DO I get for them bubbler jets ?
5th edit:
According to the pipes table:
I can also use 4 pipes sized 1.5" for the jets, that way I can have 8 jets split to 2 on each pipe and control their pressure easier... right?
