Metals in my pool
You are just consuming FC...completely normal.
Dose your pool to get to the high end of the FC/CYA range here for your pool. Link-->FC/CYA Levels
Test and add chlorine daily. You will begin to learn how much FC your pool needs daily.
Reactions: Mdragger88
How high are we talking? FC/CYA level math says my target to be 5-7. I used to have problems with high CYA like over 100s, but with evaporation and adding more water those levels got better. I worry about that happening again, but I use the cl tabs to keep CYA UP, before this test my cya was 30, placed cl tabs and a week later it was up to 40.
Keep it at 7 or 8 until you learn how much FC you are using. If you start at 8, and your FC demand is 4, you will end the day at 4, which is above minimum. Make sense?
With a CYA of 30-40, your FC demand will be midrange...as I said, 3-5. You can even raise your CYA to 50 and it will reduce your FC demand a bit more.
