- Oct 25, 2015
- 5,824
- Plaster
- CircuPool RJ-60 Plus
Sorry to be late to this party. Read through this thread quickly and see you replaced the heat exchanger bundle and I definitely think that was wise. I've read about water in the tub causing several errors. As James pointed out the only way to get water in there is a tube leak or back flow through the vent. It's almost always a tube leak. Your tube bundle looks pretty bad. The air flow switch is difficult to bypass. The easiest way I found to do it was to jump LV to the terminal on the Fenwal after the fan starts. Of course do this only momentarily to listen for the gas valve to close. The ignition cycle requires a certain amount of time where it detects airflow through the fire box to reduce the chance of an explosive mixture so you may have to wait a few second. One thing I noticed in your video is the single flash of the fenwal occurs before the fan is shut down. I've never seen this before. Could be one of those weird things that happens with water in the firebox. Sorry this is so late of response and I hope it's helpful. To check the air switch put an ohmmeter on the contacts and gently blow on the hose. It should change state with only a slight puff across the tube. Also be sure the tube connections are not cracked or obstructed. Doesn't take much and mud-dobbers seem to like them. Lastly, on the hose that connects underneath the fan casting make sure it is connected. It's very easy to unintentionally have it pull off when you reconnect the gas union.
I feel your pain when I look at your heater all torn apart... brings back visceral feelings of "it's you against me and I'm GOING TO WIN!" I did eventually with huge help from James, Allen and others. But it was very painful. Just keep this in mind. The parts were expensive but beating it was priceless!
I hope this helps.
Chris
I hope this helps.
Chris
