Thanks everyone for all of the help. I was at work yesterday and haven't had a chance to go through James' full troubleshooting procedure. I will try putting the system into boost mode.
The 24 volt light should work.Blue to Blue/white is 37.5 Volts AC at 6 amps and this is the power for the cell.
I like the idea of being able to control the SWG thru my Aqualink, but it seems like the Jandy AquaPure SWG's are junk. It's a regular 2-year replacement cycle at $1000 each. My Hayward system at the last house lasted twice that long, and I hear that Pentair is even better.If you are going to keep your Aqualink then stay with the Aquapure.
The IntelliChlor cannot be controlled by the Aqualink and will only do 20% adjustment increments.
Yes, but Pentair IntelliChlor without Pentair automation can only be adjusted in 20% increments.I hear that Pentair is even better.
TruClear is junk. Worse than the Aquapure.What about Jandy Tru Clear? I just came across that one, and it seems to be more reliable than the AquaPure.
The internet of course.TruClear is junk. Worse than the Aquapure.
I don't know where you're reading your stuff.
Another option is to go with a CircuPool SWCG. Call them and ask about the new series that is coming out with remote control. It may mean having to work off of 2 apps but far cheaper then buying a IntelliCenter with a IC SWCG. Something to consider.The internet of course.
OK, good to know. What is the approximate cost of replacing my panel with an IntelliCenter? Would it work with Jandy VF pumps and Jandy heater?
Yes.and Jandy heater?
Mine never displayed LO. Water temp does not seem to be the issue. Boost did not help. Based on the current error codes I think my cell is dead.If "LO" is shown on the display, you can still get the cell to turn on by setting it to "Boost" the pool. This overrides the low temperature stopping production.
If "LO" is NOT shown, it should turn on the cell. You can verify with the "Cell on" light which will always light up when the cell is being powered.
If the "cell on" light is on, you should see voltage above 19V at the DC leads to the cell, if not, your PCB is dead. If you do see voltage but 0 amps, the cell is broken. You may be able to repair with some ingenuity, see my link in previous post.I would do the load test with the light to determine if the problem is with the cell or the power supply.
