Is this dead algae?
EJ39
49
Ma
Hayward Aqua Rite (T-15)
Not the best pictures but does this look like dead algae?
First time I have seen it, if I hit it with the brush it goes away.
I have a Taylor test kit, it’s doesn’t appear like dust as it doesn’t lay flat on the pool bottom like dust it almost has a texture to it. If that makes any sense, it also showed up in the same general area 2 days. I’ll test the water and get some
Numbers
I've found that with the pump running, any sediment in my pool, no matter what it is, shows up in the same place due to the way the returns push the water around below the surface.
Post up your test results and we can see if anything looks off :)
You might be spot on with this, tested last night and again this morning.
CYA 50-60
PH 7.3
TA 60
FC 8.5.
Tested the same thing this morning using the 10ML sample.
Tested again 4-5 hours later and I’m getting the same 8.5FC I’m assuming I’m not losing much if any due to the fact it’s 60 and cloudy?
Your SWG should be keeping the FC to where you want it, if that's running.
If it is dead algae it's not much if you didn't lose FC overnight. I'd say it's probably dust/dirt/organic matter that's blown into the pool. :)
I’ve had my SWG turned off since yesterday hoping the FC would come down a little.
Thanks for all your input
Reactions: IceShadow
