I recently upgraded my intellitouch with an intellicenter control panel. I have it up and running fine same as how it was operating with the intellitouch. I have a different brand SWCG - which I believe is wired to the pool/filter relay. When I run the spa and heat, it automatically ramps up chlorine and it's too much. Can I wire this to a separate relay, and program that relay to come on when pool is running. It not under spa mode? Thanks for any advice.
