- Apr 22, 2021
- 111
- Plaster
- Pentair Intellichlor IC-40
Moved from here.
I just received my MasterTemp 400 BTU Heater and it does have the RS-485 COM port connectivity capability. I have a few questions before I do the install, that I could not find clear answers to:
1) For the Auto bypass using the IntelliValve: Do I connect the IntelliValve directly to the MasterTemp heater to control the by-pass (this is standard MasterTemp functionality) or am I now better off to connect the IntelliValve to the IntelliCenter, and allow the IntelliCenter to control the activation of that valve?
2) I have a Sub-panel and the IntelliCenter Power Center at the equipment pad. How best to wire the Heater
a) Directly from the Sub-panel, but then the Heater is on all the time - I would like to avoid this.
b) Via the Load side of the Pump relay, then the Heater will only be on, when the pump is on. The 20A breaker for this already suports the IntelliFlo pump, Salt cell transformer and the cleaner booster pump.
c) Via its own IntelliCenter relay, and have the IntelliCenter activate the heater when it calls for heating (Heater is on the least amount of time, but this might be quite complex to setup)?
3) Does the heater need to be connected to a GFCI breaker? No reference to this in the installation manual.
Any guidance to the above will be much appreciated.
