Intelleflo vsf RW-485 cable connector
Forest,
It is a screw-on connector..
But you should just put the automation into the Service mode and then you can use the pump's display.
Also something to check... When in AUTO the pump's display should show "Display Not Active".. If it does not show that, then the automation is not controlling the pump.
Jim R.
Forest,
Also something to check... When in AUTO the pump's display should show "Display Not Active"..D If it does not show that, then the automation is not controlling the pump.
Jim R.
Thanks Jim,
I got the connector apart without damage and reset the pump, but no change in it's action.
When connected to the EasyTouch panel the pump display does show "Display Not Active".
My current issue is that the pump seems to go through a high speed "prime" sequence and then the rpm goes to zero. You can hear that the pump is 'on' so to speak, but no flow/rpm. It is a salt pool that we are converting back to chlorine due to the salt corrosion of stone coping. The salt cell is still in place and displaying low salt. I wouldn't think the cell is telling the Easytouch to shut down the pump?
Otherwise still digging around for ideas. Thanks
Forest,
Salt has nothing to do with your stone coping issue.. It will continue to erode because of the quality of the stone.. But, it is your pool and you should do what you want.
The salt level has nothing to do with your pump issue.
I suspect that you have an EasyTouch issue... Most likely you have lost your speed settings..
What programming have you recently done to the EasyTouch..
Jim R.
Forest,
For the pump to automatically run several things have to happen
1. You have to be in AUTO (NOT Service mode)
2. A Circuit must be on.. Can be any circuit, but usually the Pool circuit.
3. The circuit that is on, must have a speed assigned to it. (As in Pool = 1500 RPM)
4. The pump Type must be correct..
5. The EasyTouch must be controlling the pump. (When you have an IntelliFlo pump, the display will say "Display Not Active".
Jim R.
Forest,
Jim R.
Thanks again Jim,
as for the salt corrosion issue, is it your opinion the 'poor quality stone', which i agree I have, corrode the same whether it is a salt or chlorine pool? what type of stone do you have and is your pool salt or chlorine?
Now back to my pump issue. I did go into my screen logic config app and removed the salt cell, but added it back just in case that mattered. I have scrolled through the EasyTouch menus, but only after this pump issue came about.
I'll keep at it and check the speed settings.
Thanks
Forest,
Check this ScreenLogic page..
It is the opinion of the majority of saltwater pool owners here at TFP.. It is also my personal opinion and based on my experience with my three saltwater pools here in the DFW area. I have seen no corrosion of any kind on my 3 pools.. They have been saltwater pools for over 10 years, with the same equipment, EasyTouch, IntelliFlo, and IC40...
So, here is my story that I have told a few times before... :mrgreen:
I bought a rent house that had a pool. Both the house and the pool needed a total upgrade. We had the plaster redone, the waterline tile replaced and new Flagstone coping installed.. For about three years, after the upgrade, the pool was a chlorine tablet pool.. Almost immediately, some of the flagstone seemed to shed very thin layers of sand.. You could look at the stones and see that there were good stones and bad stones. Often right next to each other... My robot cleaner would pick up the sand and it did not take long for the filter basket to turn almost brown. About 10 years ago, I installed the Pentair equipment, including the IC40 salt cell. Now, 10 years later, the good stones are still good and the bad stones are still bad.. The saltwater did not make the shedding any worse or any better.
Thousands and thousands of saltwater pools are built in all the other states, but only in Texas it is said that the "evil saltwater" will eat your stone work.. Why only Texas??
In any case, that is my experience, yours may be different. All I know it that I'd just as soon fill in my three pools, if they could not be saltwater pools. :)
Jim R.
Thanks Jim,
You have me rethinking the changeover to chlorine. As for my pump issues, seems as though the rpm settings had been "lost" as you surmised.
I have screen logic config app on my iphone as they did not have a Mac version at the time i needed it.
my pool is 20,000 gallons so i need about 30-32gpm (1500rpm)for a full turnover on a 10 hr run day.
Also have a valve actuator failure that i am startig to research om TFP.
Thanks again
Forest,
The idea that you have to "turnover" your pool water X times a day is a myth.. It is just not true..
Chemicals keep your pool sanitized and clear, not the number of times the water passes through the filter. The filter is only there to capture whatever falls into your pool and floats.. By the time the filter starts to see algae, you have already lost the algae war.. :mrgreen:
Does not mean that you can't turnover your pool water a million times a day, if you want, it just means that it is not required to have a clear and beautiful pool.
Jim R.
