Installed Circupool RJ-60+ - all good
mwnave
3
Venetia, PA
Big evening...finally made the conversion to SWCG. Added 840lbs of salt a couple of days ago, made sure ppm was 3500 today. Installed plumbing and wired to my Jandy RS. Originally wanted online capabilities but after consideration, went with direct wire to pump load circuit. Everything working fine and running my pump at 1750rpm with RJ at 25% (should make about .75 pounds per day of Chlorine). I run my pump at low speed 24/7. Freedom from "the jugs". And...
