Home owner pool build- AZ
I LOVE the accent color around the pool!! Well done!
Tell me this. How did they do the lines? They sure look even and straight!
They had a 2x2 piece of wood with a thick marker on one end to mark a foot and on the inside end against the pools edge it had a roller like a nail but it spun. They marked it and than used automotive tape to tape it off following the outline. It's honestly very well done.
Reactions: kimkats
If you leave a tablet in the tube and don't have it open the "gases" can build up and cause problems down the road. If you use them just make sure to remove the tablet when you are not going to use them. You also need to be careful where you put the tube so make sure it does not "back up" into the heater or such.
Reactions: Jdmcbuilt
It is not the floater. It is what is IN the floater! Those tablets add CYA to your water. After a while your CYA will be so high you will have drain and replace some of the water. See this chart: FC/CYA Levels As you can see the higher your CYA the more FC you will need. After a while it will be unmanageable.
what would be the alternative?
