We lost our pool guy & I decided to try this on my own, but things are not off to a good start.
The water is overall clear, but slightly cloudy, and I've been battling algae creeping in along the edges of the ledges & steps.
I have a test kit & just used it for the 1st time, so bear in mind my numbers mayyyy not be 100% accurate. BUT they're not too far off from the pool store test I'd been relying on prior to today, so maybe that's a good sign? Haha
PH: over 8.2
Chlorine: basically none (palest of pale pink)
FC: 2.5
CC: 1
TC: 3.5
CH: 300ppm
TA: 100-110
CYA: over 90 - if eyeballing the tube counts, 110?
From what I've read, I feel sure y'all are gonna say to drain some water & I've accepted this will be a painful water bill.
Should I add more liquid chlorine, too? Do nothing until the CYA is within the ideal range?
PH: over 8.2
FC: 2.5
CC: 1
TC: 3.5
CH: 300ppm
TA: 100-110
