- Oct 18, 2009
- 3,648
- Plaster
- Hayward Aqua Rite (T-15)
Great build so far. You might want to have your PB change out the Blue handle valves with Jandy or pentair never lube valves. Our PB originally put in the Red handle valves and we had them changed out for Pentair never lube valves.
Just an update for those that care. Sorry I've slacked on this. Part of this thread was to allow me a journal of our progress which has mostly been a good experience for a pool build except for one major thorn.
I've wanted to share a picture of the equipment pad for those that like to reference these, like me, or for any insight into any problems anyone may see.
Equipment Pad
I think it is pretty clean.
- We had a chlorinator added, as mentioned previously, in case we find the salt too much for our stone although I don't think it will be a problem.
- A light was added that will be tied into the automation.
- All equipment except for the pump are attached through unions and the pool builder knows I want the same for the pump.
- One can't tell the slant on the pad from this pic too well. At first I was going to have the pool builder redo it (yep, I was probably pushing it) but I have decided I can live with it since I will be the only one knowing it and probably (hopefully) won't see it much.
Obviously, the plumbing and electrical have been run. I won't bore with those pictures as I doubt anything new is derived from this. I may post a pic of the wiring inside the Easy Touch just in case there is something to worry about.
