Check out mmm OCLT! Wil slam again a few more times today and check in AM. To finish. Then, on to other pool questions!
Ha. No. I really just want to go to bed. I did raise to slam levels several times today I just don’t want to do it again before bed because I don’t wanna have to wait another 30 minutes to test so if I’m in the clear to leave it that’s what I want to do! BUT I will use that speedster in the morning to see if I lost any chlorine overnight. That thing is incredible people are crazy for not buying that !Your pool is clear, you passed OCLT, your CC <.5. YOU PASSED. Perfectly within your rights to move on.
Having said that, many of go 1 more day at SLAM levels for "insurance."
I don't think you need to do another OCLT. Buuuuuuut, if you want to, no harm. Yeah, raise to SLAM level, 1/2 hour, test, go to bed, test before sunrise!
I think you just want an excuse to use the Smart Stir!
You go do that! You did a great job, and stuck to it. I'm super proud.if I’m in the clear to leave it that’s what I want to do!
I’ll give you that. The previous several nights leading up to when I was going to really try the OCLT I didn’t bother staying up for my final test because I knew I was losing chlorine fast and I just felt confident that final edition wasn’t getting miraculously kill it all. I just wanted to get to SLAM knowing I would continue SLAM the next day. As for drops, I’m very careful, straight up and down, slight pressure, etc. but, will repeat today!First, on the salt. Every gallon of Bleach will add 2.2 lbs of salt. For your pool, every gallon of 12.5% bleach will raise salt by 18. Every 5 gallons, will raise it 100. 10 Gallons, 200. Smart stir is excellent for salt test.
Back to the SLAM. I don't know if you added or not. I know this has been a long process. Being tired after dealing with everything else in the day, last thing you want to do is fight with a pool. I think, take a deep breath, and let's take our time tonight. Test and log everything accurately. Make your addition, wait 30 minutes with pump on, then test. When you do your testing, hold the bottle vertical, drop the drops sloooowly. Let each drop form and let it drop of its own accord (very slight pressure on the bottle). This will make the drops consistent. It has, for me, been a bit hard to discern what is really going on overnight, because you log your test, addition, but not the after test (you don't need to do it for every addition, but the OCLT is critical).
Hey. To clarify on this. By leave the pool alone, do you mean covered, pump on obviously, but SWG OFF?Using what @mdragger said, test your pool a couple times before you go. We can call it 24 hour CLT. Leave the pool alone, with the cover on. Test at the beginning of 24 hours and the end of the 24 hours. Do it a couple times when you are not going to use the pool. This will give you a decent idea of the daily FC loss. We can set it off of that.
Can you arm your neighbor with the FAS-DPD and have them adjust your SWCG weekly?
This is in your sig. Chlormaker CL02 swg. Can you point me online, I couldn't find this, just a spa module.
