MITBeta
- May 28, 2020
- 1,239
- Vinyl
- CircuPool RJ-45 Plus
You should get your pH into the low 7s now, but 7.2 is suggested.
Then you will use less chlorine overall if you increase CYA to 30-40. If you're confident in your 20ppm read, add another 10ppm and boost your FC level to 12ppm for the SLAM Process.
