Help with algea
How frequently are you testing FC and adding bleach/chlorine? You need to be doing it 3-4 times per day at a minimum, and more if possible. If I was home, I'd check it every hour if I were you.
Any time your FC drops that low, algae just begins multiplying again. So it's two steps forward and one step back. The more you keep FC at SLAM level, the faster it will clear up.
What happens if I add chlorine during the day in the sun?
You continue to kill algae. Some will be consumed by the sun, but allowing the FC to drop during the day extends the length of the slam.
Test and add every 1-2 hours when you can. Will go faster.
SLAM on!
Reactions: jeffchap
In case it wasn't clear - you're not just dumping some chlorine in once a day and hoping it takes care of it.
You should be testing often, at least 2-3 times a day but once an hour if possible. When you test, you find out how much FC you have. Then you add more, enough to get you back to the SLAM level for your CYA on the FC/CYA Levels.
If your CYA is lower than 20, add another 10ppm in a sock by the return. It will take 2-3 days to show up on the test, so just figure you're at 30 and use that FC target of 12 with each addition. Then after 2-3 days, test again - if it's higher than 30, adjust your FC target to the new CYA level. :)
Reactions: jeffchap
It's been a while since I posted, and had to start over fresh because chlorine dropped too low and algae flourished. So here is an updated picture of how it looks so far after about a week of adding chlorine and checking multiple times a day. How do you think it is coming along?
It's definitely less green than it was. Just keep up with the chlorine additions as frequently as possible. Each time your FC drops below SLAM level (40% of your current CYA level), the algae gains a foothold. Stay on it and it'll be blue again in a couple of days. Then it will start to clear.
Reactions: Kivare
What are your current levels? How often are you checking and what FC level are you adding to target?
ph is about 7.8, cya is 40, fc was 11.5 last time I checked about an hour ago and added 3 gallons of chlorine. checking about every hour or two, and fc level is 16 trying to target. Just check fc and it was 15.
Yes, I feel more confident about what i'm doing and seems to be moving in the right direction. I can't wait to use our pool again.
The good news is, it's safe to swim as soon as you can see the bottom at the deepest point. It's safe to swim with FC at SLAM levels, so you don't need to complete the SLAM first.
Reactions: Kivare
Hello, been at this for a while now but stuck with a cloudy pool. Have put in so much chlorine and still same results.
Note your clean pressure. Say it is 10psi. When it rises 25% to 12-13, backwash. Should be good to go. Just at least check it maybe more often, that may help.
Reactions: beeswax
That's a TON of improvement! Keep adding liquid chlorine...no shock, tabs, or stabilizer and follow the backwashing instructions above.
You're done once you meet these 3 criteria:
- Clear water
- CC less than 1.0
- You pass an OCLT
As others have said, stick with it. I've been where you are now... not long ago. I think the main issue now is that you have a pretty large pool and it takes a long time to clean it up with the sand filter. Here's what my pool looked like on May 19th. You can see it has the same dull look with lack of clarity.
And here's how it looked on June 10th.... I would say it's even clearer now a week and a bit later.
Like you, I was pretty frustrated and questioning the progress but it works... just takes a long time! You may want to try doing a deep clean on the sand filter. You'll be amazed how much Crud comes out of it. Make sure you run the filter 24 hours a day. Don't skimp here to save on utility cost. Just keep that pump running, and keep FC in the right spot and you'll get there. 100% it's expensive to get the pool back in the right condition which has motivated me to ensure that I don't have this situation next year when we open. Good Luck!
Reactions: Kivare and beeswax
