Good morning all!
I found an old thread where this was discussed but wanted to start a new one for better feedback. I have two questions i need help with....
Background: Pool is finished, been using it for months and we did it ourselves. It's a steel panel pool, vinyl liner, about 40x20 double roman. Around the pool currently i have about 12" of processed stone that's been compacted in layers.
1) Next year i want to install stone cantilever coping to overhang the pool edge slightly and then techobloc pavers around the entire pool area
- I do not have a concrete collar around the pool, is this necessary to install the coping? Can I just use mortar under the stones up onto the steel panel to fill the void between the processed stone and the coping stones? Or is the best way to install a collar, then use adhesive to install the stones?
2) I saw in the old post someone had steel rebar it looks like all around the pool, with rods every few feet and they were all bonded. Is this necessary for a paver block decking? When we had our inspector come out he said bonding on the surface was only needed if i was going to do a concrete deck with steel or wire mesh. The paver stone should all be non-conductive and when/IF i pour a thin collar i won't use rebar in there either.
Hard to find some of these answers on my own with the google machine, so you guys are always life savers, thank you!
