All in ground pools have to be bonded so you will need to have the bonding connected to any metal parts and under the deck ( any metal 5 feet from the pool I do believe) to include the water and pump... this is one of the bonding grid you will need under the deck all the way around the pool... Erico POOLMESH3100 Copper Pool Mesh 100-ft x 3-ft Caddy®
Cowboy , I'll be back for advice from you later on if that's okay? Plan on doing a steel in-ground in the spring. I know the pump has to be grounded I didn't know there needed to be something under the deck as well.
