+1, And will be the perfect spot for landscaping because if the space is just sitting there unused, it might as well be pretty. The wasted space instantly becomes a focal point/ accent areaThe pool will divide your yard and in usable and not-used space. So anything on the far side of the pool won't be used much
it's very tempting for sillyteenagersHUSBAND to think they can make the jump into the pool.
I had to stop my husband and his brother from trying to get onto of the pool house and jumping from it into the 52" pool MEN! They had the ladder all set up when I found them REALLY?? sigh............go put it up and behave!
Love the colors of deck and coping. Is that silver travertine coping with cooldek/sundek? What color is the deck?While I like the look of free form, I also had limited space to work with and an easement , so to get the most pool space, we went rectangular.
View attachment 128045View attachment 128046View attachment 128047
Thanks, we were really happy how it all turned out. Coping is Rustic Tuscany and cool deck is Arizona Sand.Love the colors of deck and coping. Is that silver travertine coping with cooldek/sundek? What color is the deck?
+2 on this. Consider the entire yard and how you will use it after the pool. I would second pushing it back to the rear setback. Think about future patio, sport court, bbq, etc...The pool will divide your yard and in usable and not-used space. So anything on the far side of the pool won't be used much
This is a very common misconception that I find with all my friends with shaped pools. They consider the outward curves as ‘more space’ when in reality the inward curves take it away. Forgive my horrible renditions, but I drew an example. Let’s assume the furthest outside measurements are 20x40View attachment 128042
My shaped friends think in their heads about a rectangle that would fit inside their pool like this but it’s not apples to apples because their pool is considered a 20x40 and that rectangle is a 16x32(? ish). Like this.
In this case, then yes your 20x40 needs a bigger cover and has ‘more room’ than a 16x32.
If the outside edges of both the curved pool, and the rectangle pool were at the same place, they would both have the same (2ft ?) overhang from that edge where they intersect, no ? I think the curved pool cover, just like the curved pool just look bigger. Now the price is certainly more due to the custom edge the whole way around.However because of the curves, the cover needs to be curved as well, and that may mean cutting the curves out of a larger cover,
They have certainly been a hit in this thread. I don't disagree.If I were building a pool it would likely be a rectangle, maybe with those curved corners, I like that
Yes, however you need to consider that the overhang is partly on each side, so to get a cover that fits, your either cutting from a larger piece, for example if your pool is 16' wide, and your overhang on both sides is 2' you need to start with a 20' wide piece of material. Let me explain this way, the cover is 16' wide, the reel it fits on is 16' wide, but you need to fold over a 2' section at the middle for it to fit properly on the reel, because the reel can not bend to fit the curves. The pool volume may be the same as a rectangle, but the cover isn't if you want it to sit on top of the water. Like I said, I can't show a picture of the pool from above, because the yard with the pool in it, is one big blanket of snow....If the outside edges of both the curved pool, and the rectangle pool were at the same place, they would both have the same (2ft ?) overhang from that edge where they intersect, no ? I think the curved pool cover, just like the curved pool just look bigger. Now the price is certainly more due to the custom edge the whole way around.
Again, it’s all how you look at it.The pool volume may be the same as a rectangle, but the cover isn't if you want it to sit on top of the water
Oh no! Good thing you found them and yes, your're right it's us boys. I don't think i could ever think of a scenario where my girls would do that but my son (or a friend) would at least think of it.I had to stop my husband and his brother from trying to get onto of the pool house and jumping from it into the 52" pool MEN! They had the ladder all set up when I found them REALLY?? sigh............go put it up and behave!
I will always take "straight lines" over curves. Looks cleaner and more modern IMO. We also had limited space (those darn setbacks!), so we chose to utilize our side yard and get a not too small, not too big modified rectangular pool. HOA/City gave us the run-around on the wood deck over the easement, but they eventually "approved" it.
Thanks! Hope the OP comes up with a solution.That is a fantastic looking solution to a space issue!!
Thanks! Unfortunately we had a freeze this past winter which killed all our fence-line greenery. We are starting over within the next couple of weeks with more cold weather tolerant greenery.^^totally agree. Your pool/hardscape look amazing!
