- May 3, 2014
- 58,690
- Fiberglass
- Pentair Intellichlor IC-40
My husband cleaned it and changed the sand last summerSo a sand filter. Quite the fancy title.
The sand should be capturing the solids. Have you every deep cleaned the sand filter?
They are itty bitty particles. Like the powder shock from Walmart that didn’t dissolveSo a sand filter. Quite the fancy title.
Welcome to TFP! Here at this forum, we emphasize proper home water testing. It's the most reliable. Pool stores and their products will lead you astray. I would recommend the following:
- Get a TF-100 (link below) or Taylor K_2006C test kit. See Test Kits Compared
- Read the SLAM Process page. That's how we remove algae for good.
- Don't add anything else to your water right now except for regular bleach. But not too much until you get a proper kit and can post a full set of results. We'll coach you from there.
- Don't forget to update your signature as well.
Good job on the kit.
Your FC is very low for your CYA. See FC/CYA Levels. You may want to do a Overnight Chlorine Loss Test in the near future if your FC loss each day exceeds 4 ppm.
Thanks!!!Once you get your FC to target range, you will need about 3 quarts of 10% liquid chlorine every day. Test your FC daily to determine how much to add.
