Help Identifying Filter Model and Help with Lateral Replacement
tensec10
Active member
May 27, 2017
27
Milwaukee, WI
I always had a nagging sense there were super small amounts of sand coming into my pool, and after just opening this spring, I now have lines of sand pouring straight into the pool. Having once changed the sand and noticing .... what I now know are laterals... were in rough shape, I assume one or several cracked badly over winter.
I'm wondering if anyone can help me identify the filter model that I've got, in the attached pics, in hopes I can buy a replacement vs a full new filter.
Also, is the valve portion the same model / part as the giant ball. You can see the valves are much newer than the sand reservoir.
Any advise is appreciated. Figuring things out as I go, and have had some great success so far!
