Hello,
I have a Hayward MaxFlo VS pump. I think I might have a side suction air leak and the specific symptoms I noticed along with pictures of my setup are below. I'm looking for troubleshooting steps I can try to find the leak.
1) its taking longer to prime
2) the suction as well as return is weaker once it did prime
3) the pump lid never fills completely with water like I'm pretty sure it used to and when priming, it looks like there is a mix of water and air being pulled in
4) there are air bubbles coming out of the return jets
Things I have tried:
1) I first replaced the orings in the diverter valve since it was leaking water and I thought I heard air once I turned off the pump
2) I replaced the oring in the pump lid
3) edit: after searching similar issues, I tried putting soapy water on sections between the pump and the ground hose but haven't found anything yet.
Note: I used 3in1 silicone lube for the oring which comes in a pressurized can and isn't very viscous. Not sure if that's okay. Edit: I tried soapy water around it and doesn't look like it's being pulled in.
