hayward color logic lights
Welcome to TFP.
I think you are asking if you can have mix 120V Colorlogic lights and 12V Colorlogic lights and have them all color synchronized.
I believe the answer is yes. Maybe @1poolman1 can confirm.
Make sure you use a Hayward transformer or install a snubber in the transformer you use.
  • Snubbers & Lighting-1.pdf
But staying synced would become difficult since the method of changing colors differs for each voltage system.
How is the synching method different for the 120V versus 12V lights?
I stand corrected.
From the manual for the Colorlogic lights.
"Multiple Hayward ColorLogic LED lights may be operated independently, or they can be easily synchronized so they will all display the same colors and shows at the same time. For light synchronization, all lights must be wired to the same switch."
