- Jun 22, 2014
- 52,037
- Fiberglass
- CircuPool RJ-45 Plus
Hello!I tested and went from 17ppm to 10.5 ppm in about 18 hours.
- Test as much as needed to maintain the FC level
- Be sure the FC is at the proper FC level based on the CYA per the FC/CYA Levels
- Inspect, inspect, inspect. Algae is a sneaky bugger and can hide anywhere. Things like behind a light, liner folds, in the skimmer, or under a main drain cover. If you have a ladder or steps in the water they should be out of possible. Those are always algae homes.
- Circulation; be sure the chlorinated water is moving well in all areas
- Update your signature with all of your pool and equipment info we review it at each post.
- Finally, brush all surface areas to break-up any organic biofilm. Vacuum as needed and backwash/clean filter when pressure increases by 25%.
Algae simply can't survive in elevated chlorine water unless the FC/CYA ratio is not correct and/or there is an active growth somewhere, so remain vigilant for both those issues. You'll get it.
