- Jun 22, 2014
- 52,030
- Fiberglass
- CircuPool RJ-45 Plus
Chances are power will remain on and everything fine, but being away you would be preoccupied with the pool. You have the option to ensure you have a good-strong FC level before leaving, then you could just shut the system down. Drain the filter and pump pot and just leave the pool off for those 3 days. Perhaps wrap any exposed plumbing and valves and cover the entire pad with a heavy blanket and/or tarp. I don't see a need to do like northerners who blow out the plumbing lines. Lines exposed and equipment on the pad is you biggest concern. You might also place a cut up pool noodle or plastic jug in the skimmer just to be safe.
