Hi! The outlet pipe coming out of my DE filter (FNS Plus 60 sq. ft) has a slow leak where indicated in the photos. From the parts diagram it looks like the leak is coming from part numbers 28 or 29 where the pipe meets the filter. I'd like to detach the outlet pipe from the filter housing but I don't have a wrench big enough (the diameter is large) and it's too tight to loosen by hand. How would you go about removing the outlet pipe from the filter? Do I need a special wrench? Also, does anyone know if there other ways I can try and diagnose/fix this leak? Thank you!!!
