Second what JamesW said. Short wire to jumper the two and then see what happens.
The amp/voltage readings should be different for the T15. I just checked mine and it's at 25.2v, 5.99a.
Here's what the board manual says:
2. Cell voltage (typically 22.0 to 25.0 volts when chlorine is being generated, otherwise 30-35V)
3. Cell current (typically 4.50 to 7.80 amps when chlorine is being generated, otherwise 0 amps)
From the inyo pools site, the amperage ranges for the different cells:
- T-15 Amp Range: 3.1 – 8.0 amps
- T- 9 Amp Range: 2.3 – 6.7 amps
- T-5 Amp Range: 1.9 – 5.7 amps
- T-3 Amp Range: 1.3 – 4.5 amps
In that thread the OP was having the same issue you're having - board was reading a salt level different from the water tests.
My aqua rite generator is showing a reading of 2000ppm while pool store reading is 3500. I have cleaned the cell 2x. The cell was replaced 1 year ago and the large circuit board was replaced at the same time. The display board was not replaced. The “low salt” light is on and there is no chlorine...
www.inyopools.com
If you end up having to buy a new board, the newer versions have a firmware setting for the cell type - no jumper on the board. It's one of the options when you press the diagnostics button in the later versions of firmware.
