VinnyinNJ
- Jul 20, 2022
- 1,051
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I believe most if not all AG filter systems require to be below the water level of the pool and they don't self prime, at least that's has always been my thought. Although I had one of those caps to put onto the skimmer if I needed to manually vacuum I would just use the automatic cleaner hose. It had a self regulating valving system that would let the correct water flow into the skimmer. But the few times I did use it I tok the dkimmer basket out of the skimmer.
But with that said I would typically go to the return, have it force water through the hose until there were no bubbles coming out of the vacuum or auto cleaner then quickly hook the end of the hose with the valve I spoke about into the skimmer. All the debris went into the skimmer basket inside the pump, If it picked up a lot of large debris (leaves) then I would have to stop the process and empty the pump basket. Whenever my last filter seemed to be getting too much air intake I would open the air valve on top of the filter and let the air escape ... it also seemed to take care of the pump as well when I did that. I don't have my new pool yet and I'm getting a Hayward sand filter so it'll be a learning experience of what to do with that; it could be a whole different experience!
