Ph & ta are “married” as far as chems are concerned- if u add a chem (acid) to lower one the other also gets loweredSo to raise ph on its own, aeration is the only way? I can't add something to raise just ph?
I've added muriatic a couple times, to keep ph at 7.6-7.8.
And the 3 B's, can you explain what they are used for.
Unfortunately as things are that we have discovered, aeration is the safest way to raise pH without raising something else with chemicals. As far as the “3 B’s”, I was new and bought them but did not need all of them. That was the point…that I only needed bleach out of the 3 B’s (the other two were baking soda & borax). The point is you may not need all of what you thought you would…I just need the bleach (aka liquid chlorine), others are stuff I still have sitting around. You can use chemicals to raise pH but it will raise something else also like TA. So far, only aeration will raise pH without TA rising. That is not a clique thing, that is science. I am okay with not using the extra stuff I bought, as long as what I am using keeps my baby pool good. That was on me, and that is okay…I am learning and stuff happens along the way. In my opinion, it is easier & cheaper to tie a hose to my ladder to raise pH if I need to vs buy some item that will affect something I do not want it to. The last thing I want is for my TA to go up lol.
Adding higher ta fill water to top off the pool will contribute ta to increase which in turn causes ph to rise more quickly.Thanks for the science and clarifications on additives. I guess bottom line for me right now, based on tests, I will use some MA to bring down ph a bit (from 7.8 to 7.4) and that will lower my TA a bit. And that keeps ph in the ideal range.
Why does TA rise, what causes are there for that? Just so I'm aware of the external factors.
Other than FC and CYA, it seems like other things, like TA/PH rise on their own. The additives I'm using so far are to lower things usually.
It sounds like it did, but how? Did the water level drop allowing you to see & hear air out of that the return jet, or was that happening below the surface?so did the pump take in air somehow?
Water level was bang on. The hose is over the top rail of the pool to go into the skimmer. At the far end of the pool, I pulled the hose to it's full length (25 ft hose, 30 ft pool) and I wonder if that slightly lifted the vac plate off the skimmer basket, just enough to allow air to seep in and eventually lose suction for the pump. Can't think of any other reason.It sounds like it did, but how? Did the water level drop allowing you to see & hear air out of that the return jet, or was that happening below the surface?
Not on its own. More than likely you are just experiencing a small testing variance. Keep in mind you can easily have about a 10 ppm variance in the test itself. But when we perceive our result as being something like 45, we always round-up anyways. So a CYA of 50 seems good.A week ago I had my CYA at about 45, today it was at least 50. Can it rise on its own?
Good to know. The test this morning, the black dot was pretty much gone and I looked at the numbers and it was over 50. So I added more to completely make the dot disappear. So it's on the high side.Not on its own. More than likely you are just experiencing a small testing variance. Keep in mind you can easily have about a 10 ppm variance in the test itself. But when we perceive our result as being something like 45, we always round-up anyways. So a CYA of 50 seems good.
It will. The rate of drop varies by pool, some anywhere between 5-10 ppm each month or so. It will probably drop a little when you close as well.But it will slowly come down over time?
While I was vacuuming, once in a while I'd hear a slight gurgly sound in the hose as it floated on the surface, thought that was normal, but maybe not.I doubt that is the reason, for two reasons. The vac plate is sucked down pretty well to the skimmer basket. It's not easy to just work it free. Also, the top of the simmer basket/vac plate should be below the waterline anyway. So unless it created a whirlpool and sucked air down (which you would likely notice) it would not suck in air even if it was to lift up
Look at the parts that are above the waterline next time. The hose cuff that is connected to the plate and the part of the hose that is out of the water. See if you can her air being drawn in anywhere.
I would walk along it and listen. you should be able to hear itWhile I was vacuuming, once in a while I'd hear a slight gurgly sound in the hose as it floated on the surface, thought that was normal, but maybe not.
How would I test the hose for a hole?
That is basically what I doLet's talk winterizing. I read your article and a couple old posts.
I'll break all my questions into a few separate posts so that none of my questions get missed. I know it's difficult to reply to long multi question posts. So thanks for your patience.
Finally found a company to close my pool. They had October 6 or 21, I chose 21 just to make sure water is consistently around 60 degrees. But leaving it until 21st means dealing with falling leaves here in Ontario.
I'd like to deal with the water myself; service companies include chemicals but possibly things I shouldn't add, i.e., non-chlorinated shock, clarifier, copper algaecide. I'd rather buy the proper chemicals and prepare the water myself. Then let them do the equipment and cover.
Is this approach simple enough for a first timer like me?
My next post will be chemical questions.
