- Jul 21, 2013
- 53,469
- Plaster
- Pentair Intellichlor IC-60
When I test my pool pH, the reading observed immediately is always a level lower than the reading observed after say 5-10mins.
Example, I got a reading of pH7.2 right after pH indicator mixed with the water sample. I kept the sample, with the lid still on, for say 5min later, the reading became pH7.4. So do I take the pH reading as 7.2 or 7.4?
A pH of 8.0 is fine if the other parameters that effect CSI (TA, CH, and water temp) are in good ranges or perhaps slightly low. Then it all compensates. That's why the PoolMath too and APP are so valuable because by entering all those numbers, it does the work for us. But remember, for the regular residential pool owner, there's no need to get overwhelmed with CSI as long as you keep all your levels within the TFP ranges. Hope that helps.my question is, will pH8.0 pose any problem? Is it absolute critical to have CSI at the above range, even though I have maintained my pool chemical level based on TFP recommendation?
In that case, you would want to keep a close eye on the pH and overal numbers in the PoolMath tool or APP. As water temp increases, especially over 80 degrees, it influences the CSI and usage of chlorine. So a pool's ability to develop scale if the pH gets too high, or grow algae if the FC drops too low, become more of a threat. With each season you begin to see this pattern in your pool and know how to adjust. Just stay close to the PoolMath tool/APP and always reference the FC/CYA Levels. Have a great day.my water temperature is between 84-86 deg F throughout the year.
? yes.... I am almost there, should finished the 7th pack of 1kg Trichlor this week. Then will be fully on SWG next week.Looks good. I bet it was a tough battle getting your CYA up to 70 with trichlor. Good job!
There has been light rain daily for a few days now over here. So this might be the reason. Thanks for highlighting!If you are adding significant fill water or rain water, that can effect pH.
Salt is not depleted by the SWCG. It only leaves the pool by you removing the water from the pool.
