- May 3, 2014
- 62,729
- Fiberglass
- Pentair Intellichlor IC-40
There is minor aeration effect from hydrogen. I assume your TA level has been constant.
I would have held off adding stabilizer before you do as Marty advised. If you should you need to slam it'll need more FC to achieve the same outcome.
Once I turned on my SWG, I see tiny bubbles coming out of the returns(Hydrogen gas?), almost like carbonation from a soda. Could be contributing to Ph rise, and unwanted aeration.
I’ll take the twice a week or so muriatic acid additions compared to daily liquid chlorine additions. I did the daily liquid chlorine for a month while the plaster was curing and don’t miss that.
I'm betting you won't need to SLAM. You might just need to get the FC up quickly with LC and let the SWG take over again.That's a good point, that I wasn't thinking about earlier today when I did it. Too late now, but wish I'd have thought of that.
Nik,
Where are you trying to keep your pH??? Most SWCG pools like a pH of about 7.8.. If you are trying to keep your pH at 7.2, you are just causing yourself a lot more work.
The rate your pH rises is not linear. For mine, it goes up from 7.5 to 7.8 in just a few days, but will take weeks to go from 7.8 to 8.0 before I have to add acid. Give that a try and see if it lessens your headaches with acid.The thing is, with constantly raising PH, if I try and keep it at 7.8, I'd be worried I'd be over 8.0 in a day or two, so I typically will lower it to 7.5-7.6, so I at least have a little reprieve from worrying about getting to 8.0.
Thank you so much for posting this, I really appreciate it.The rate your pH rises is not linear. For mine, it goes up from 7.5 to 7.8 in just a few days, but will take weeks to go from 7.8 to 8.0 before I have to add acid. Give that a try and see if it lessens your headaches with acid.
If you don't want to keep it at 7.8 to 8.0 on a regular basis due to scaling concerns that is fine, but it should lessen your worry that you will come back to a pool with extremely high pH when you come back from vacation.
Thank you so much for posting this.The rate your pH rises is not linear. For mine, it goes up from 7.5 to 7.8 in just a few days, but will take weeks to go from 7.8 to 8.0 before I have to add acid. Give that a try and see if it lessens your headaches with acid.
When you say 'weeks' how many weeks? On averageThank you so much for posting this, I really appreciate it.
I would say 4-6 weeks between my acid additions. This is my 2nd full season with a pool, and I'm on bottle #3 of muriatic acid since the pool was filled.When you say 'weeks' how many weeks? On average
That's a good idea, for vacations, thanks.I would say 4-6 weeks between my acid additions. This is my 2nd full season with a pool, and I'm on bottle #3 of muriatic acid since the pool was filled.
One other thought is if you have a floater and some pucks, you can use that as well when you go on vacation. They are acidic and will help keep the pH at bay while you are gone. Just make sure you do not have high CYA already and you should have some wiggle room.
+1. It’s way easier to maintain a slam just to be extra sure than it is to start the next one.
to be clear, You don’t *need* to. You passed the 3 criteria. Personally I don’t like to leave anything to chance, even a small chance, when it’s so easy to maintain the FC for an extra day.
Whoopsie. I got my wires crossed that we were SLAMing. It’s just an OCLT. Apologies.What do you mean by "maintain a slam"? I think I'm far below slam levels
Up to 1 FC loss is acceptable for test error. You passed.Also, I'm wondering, does going from 10.8 to 10.0 count as passing criteria for the overnight test, as you said? Shouldn't I have wanted it to be 10.8 this morning, not 10.0?
Sounds like a good plan to me. Then you will want to ensure that your SWG is maintaining your FC; this entails knowing your daily FC consumption and the run time/% needed to accommodate that.
Did you ever find out why your FC dropped in the first place?
I have no way of knowing, other than guessing my SWG percentage was apparently not high enough, and letting it go on it's own for a week wasn't smart...?
The thing is, i tested it and tweeked it multiple times for the better part of 3 weeks, before deciding to finally ease off and finally let the pool be 'trouble free' for the first time since filling it. And then a week later, 0 FC, lol.
Hopefully it just needed a raise in CYA, like somebody suggested earlier, and perhaps a SWG percentage boost.
It really makes no sense to me, because, like I said in a different thread, I was targeting FC of 7. In my ~3 weeks of tweeking SWG and testing FC, the range was 5.4 to 8.8, depending on how sunny it was on a given day, so it seemed safe. I always tested it between 8:30-9pm
Then all of a sudden, ZERO FC a week later.
I'm hoping it's not a possible problem with the SWG. I guess we'll see.
