I don't know if the stores around here sell liquid chlorine. Best I've seen is bleach.You do need your current TA to determine how much acid to use to lower the pH. The acid you show above is 14.5% I believe.
Best to use liquid chlorine. But you can use cal hypo if you have it.
120oz of stabilizer is not 10 lbs.
So how many lbs of that stabilizer do I need to add to reach 120oz?
nvm figured it out, didn't know you could mouse over to see lbs. I guess I have to add 7.5 lbs or 1.5 of those 5 lb containers I posted.
