Hi everyone, my sister has a 28000 gallon pool that I'm maintaining, and the valve setup is shown in the attached photos (with pump, filter and booster pump).
I heard when setting up manual vacuuming via skimmer, we typically keep the skimmer suction line open and close the drain suction line to enhance skimmer suction.
But if you look at my setup, it appears there are no jandy valves from either the skimmer nor from the drain line; it's just one, single suction pipe leading to the pump. So this means I can't really shut off the main drain suction to enhance skimmer suction, right?
The only jandy valve appears to be at the return, positioned AFTER the sand filter. So is there any benefit to manipulate that jandy valve (postitioned after the filter) on what I assume is the water return to the pool? Or am I just looking at this wrong? Thank you so much!
