- Apr 10, 2018
- 5,420
- Plaster
- CircuPool RJ-45
Are you using a 10 ml sample for FC testing?1. For testing FC and/or TC, when running a high FC like I need to, do you just dilute with 50% tap and multiply readings by 2 using the K2006? (like the high CYA testing method)
There are two sample sizes you can use for the drop-based FC test; 10 ml or 25 ml. Using the 10 ml size will save your reagents. Add one scoop of powder. Multiply each drop of R-0871 by 0.5 (divide by 2). You'll still achieve enough accuracy.
The Taylor K-2006 kit is a little light on chlorine test reagents. You should consider ordering refills of R0870/R0871.
Extended Test Kit Directions Archives
www.troublefreepool.com
