So I have the dreaded high CYA (about 110 ppm). Its a new to me, vinyl above ground large (20k gallon) pool. I know I need to drain/refill... and will. For now, I'm just going to be liberal in backwash/fill and take every opportunity I can to remove water and add fresh.
I know with CYA levels outside of norm it means you should have higher FC levels. Which leads me to my noob questions:
1. Why isn't this more widely communicated? Look at any strip/testkit/book, most say 1-4 ppm FC is where you want to be. Over 4ppm is bad.
2. With a CYA of 110, lets just say I should have a FC level of 10. I'd prefer to run at the min so I don't overly skew my pH readings... so lets target 8ppm. Is it high FC that's a swimmer concern, or really just high CC? Why is over 4ppm "generally" bad, and is it?
3. I have a whole 50lb pail of TriChl tabs.... I'm guessing they need to go on FB marketplace... and I need to go get some walmart bleach... right? (I think I know the answer to this...)
4. With bleach, how often do you guys test/adjust? I'm used to an inline chlorinator when i was a kid, or tabs... almost a set and forget.
5. Any other non-obvious (or maybe obvious) words of wisdom?
BTW, pool current readings as of yesterday using a Taylor K2005 (edited - was not a K2006 kit):
pH: 7.7
TA: 150
CH: 150
(balance calc gives almost 0.0)
FC was 1, added a little chlorine...
CC was 0.25
CYA is around 100 to 110.
Corrected TA is 118
Correct balance is -0.05 or so.
pH: 7.7
TA: 150
CH: 150
CC was 0.25
Corrected TA is 118
