So how's it going ? It's been a minute. Hold on.... I think I have a sneeze coming......... Ahhhhhhhhh ch
It could be that you have the extra money and time. Then it seams the right thing for you.Still not convinced that getting rid of bromine is right for me.
Thinking of keeping the bromine. New progress photos, as soon as I reach the bottom of the thread. Got a couple other issues I have no doubt you guys can help me solve.!I asked because it can effect draining & refilling options as you dont want the plaster to dry out in the sunwhen u are ready for that step there are many folks here to guide u along. As mentioned previously the best way to rid yourself of the bromine is a full water exchange.
Please elaborate on the "money and time" thing. At 69 year time is short and I'm broke so please preach!It could be that you have the extra money and time. Then it seams the right thing for you.
So, finally got that accursed cover out of the pool without dumping all of the contents.
Better than the snakes that I had.I say three frogs in the pool today. Is that a really bad thing?
1. You can siphon out while vacuuming the silt sand.Questions:
What can I do while waiting for my silt/sand rake to arrive?
The apron I suppose it is, appears to need new caulk or mortar or whatever. I this a DIY job?
I have a drain in the bottom of the pool that is rumored to either empty into the storm drain or rout through the filter. Does any attachment exist to allow me to pump that silt out and catch in a larger filter?
What are the disadvantages to simply keeping the bromine?
Can I "shock a bromine pool and then still keep the bromine?
If I'm to keep the bromine or not, should I bring the water level up to the filter siphon inlets?
Previously posted some of these, but here you go! Also learned that one of the sprinkler controls will top off the pool. However, have not begun the process of testing system and repairing expected leaks. Will a garden hose suffice temporarily for this job?1. You can siphon out while vacuuming the silt sand.
2. Yes you will need new caulk, depends if you are handy.
3. Bottom drains usually go to the suction side of the pump then trough the filter. Read #1.
4. Time and Money as said before. Since you are new, you should trust us that Bromine is not what is best for you.
5. Wildlife is always shown the door so they can leave never to return, no harm.
6. The problem with bromine is that shocking only converts bromide back into bromine. Its difficult to test and maintain levels. Did i say expensive? Oh yes! Expensive.
7. Not really, just make sure you use your bottom drain instead of the simmer drain. Post a picture of you equipment pad.
I really don't like pollen season. If it wasn't for my nasty habit of eating, I'd wish it away. Bad enough in my sinuses and vehicle, but in the pool???!!!So how's it going ? It's been a minute. Hold on.... I think I have a sneeze coming......... Ahhhhhhhhh ch![]()
Open up early? It is the 2nd week of April. We started our pollen storm a month ago.Open up early and have a green pollen pool
Thank you for responding so quickly. By "Wildlife is always shown the door so they can leave" do you net and re-locate them on the property or?1. You can siphon out while vacuuming the silt sand.
Your pump has 3 inputs. One controls 2 and the other control 1. A wild guess would be that those 3 inputs are:
Skimmer
Bottom Drain
Vacuum port
You need to figure out which is which by closing 2 of them and testing and so on. Make sure your filter is in recirculate, which right now is in the middle of 2 positions which is not good.
The multiport valve is attached to the sand filter and is for directing water to different plumbing for multiple functions. Don't bother moving it around if nothing is turned on. Don't try to turn on anything or flip any switches until your pool is completely full of water. You are going to have some things in need of repair but you will definitely break your pump if it runs without water.If so: where should it be while just sitting there quietly?
Possibly sillier question: must the whole thing be on to test anything?
