Is this for mainly for salt pool?pH will tend to climb because the spillover will cause some aeration.
Jandy 3 way valve cost about $75, submergible pump cost less. Those on the pic 3 are not lights it has holes which look like drains at the bottom of the pool. I am thinking it might be additional drain like bottom, but not sure.but based on how much those Jandy valves (the only one to get IMO) cost current
Thank youIt usually has additives, like iron and has bit several members here.
Going forward use diamond brite and verify the bag says pure / 100% / etc.
This is it.. use the TFP methodology!Is there any system to reduce usage of pool chemicals?
Define best?? FAS/DPD is the most accurate chlorine test with the widest range for our purposes in a pool.What is the best water tester like Chlorine, etc?
What is TFP methodologyThis is it.. use the TFP methodology!
Nice job!... I wanna see a pic of your hands! Yeah once you paint the pipes no one will never know you were finger painting with primer! (except your manicuristI have to re-work plumbing, except prime every where
