- Nov 12, 2017
- 12,645
- Plaster
- Pentair Intellichlor IC-40
There's another consideration. And maybe @JamesW can point us to the article, in which a group of kids was seriously injured when they jumped into a chlorine-automated pool, after that automation malfunctioned during the night and emptied the entire tank of chlorine into the pool.
Do you test your water for chorine before anyone gets in, each and every time? Right. No one does. And you don't need to when adding chlorine manually, or when using tabs or an SWG. But if you're going to hook up a 15 or 30+ gallon tank of chlorine to your pool, are you willing to bet your family's safety on the timer running the pump? I sure wouldn't.
As per a previous post, I'm the guy with an SWG and automated acid dispenser, and I have very high confidence I have not only the most convenient pool possible, but also the safest. And the most cost effective, to boot! And while I use a tank of acid with a Stenner pump, the tank only hold 1.5 gallons of acid, so even if it did fail, it's not going to hurt anyone, or the pool.
There's a reason everyone is trying to steer you to an SWG... actually, many reasons.
