Construction started 2/3/20
MikeFL
117
Gulf Breeze, FL
Going to start adding water this afternoon. Has anyone used Startup-Tec or a similar product? I am planning on adding 3 bottles, estimated size is 26,500 gallons.
Hisbestcatch
Active member
Mar 21, 2020
29
Melbourne, Fl
We upgraded to the 20/20. We had a nice breeze yesterday and we were happy to feel it come through the screen ... there is a lot of caution on line that the 20/20 will restrict air flow.
Oh good to know! We are struggling with the same decision and definitely want a breeze to come through! We are about a month behind you.
Reactions: MikeFL
MikeFL
117
Gulf Breeze, FL
PB had initially said no brushing for the first week and has not provided brush / testing kit. I should have researched before now (hopefully others can learn from my mistake) but based on my research (this site and several others to confirm), I need to start brushing tomorrow. I have asked the PB to bring my equipment and testing kit by today or tomorrow - hopefully they will make it a priority.
MeowMeow724
277
FL
Ours did the same, basically. "Startup" wasn't for a week after the pool was filled, and that was when they were bringing us the brush. It drove me crazy... I went and bought one myself at HD and we started brushing the next day, 2-3 times a day. Just a nylon brush for the first while, though... we just got a nylon/stainless combo brush recently because the warranty manager said the nylon one we have is just for startup brushing and otherwise, for vinyl pools. After a while ---- when the plaster is good and cured ---- the sturdier brush will be more effective for cleaning/light stains ---- but only after a while ---- I stress not right away ---- ;)
Every PB has their own guidelines but in the end, it's not THEIR pool in THEIR yard, so I am not sure that they truly go by "best practices" rather than what may be easier for them for one reason or another. As you know, my experience was a doozy and I learned A LOT from this board and thank my lucky stars I found it when I did.
I am glad you're doing the sequestrant now. Our PB/PM never mentioned it to us. I did ask them about using a filter on the hose during fill and they said that wasn't necessary, as well. We didn't use sequestrant until the second fill (when they drained and acid washed under warranty). I heard about it from this board and wish I had the first time. Now I add about 8 oz every week or two as well, which was our warranty manager's recommendation. Our coping is flagstone which naturally has iron in it and drips that and minerals into the water... I didn't know that until it was too late, either. It became apparent at the drain/fill when we had orange stains all over the plaster because they made us drain it early and then it rained for two days straight while it sat empty after their acid wash and while we waited for it to fill. :rolleyes: Orangy runny stains around our entire pool.
Sequestrant is a must and PBs everywhere need to tell their customers about it or use it as default!
I am so excited to see your finished project. This is looking amazing and I am a little jealous ;):love:
Reactions: MikeFL
MikeFL
117
Gulf Breeze, FL
Yes, that (a sequestrant) is recommended per the National Plasterer’s Council startup card and Startup New Plaster
Lowes and walmart has poles and brushes just saying..............
Now the PB is telling me his plaster rep is saying do no do anything for 72 hours while the plaster cures. That takes us to Monday which is when the PB planned to be back on site with supplies.
Any risk in waiting until Monday to add start up and start brushing??
MikeFL
117
Gulf Breeze, FL
The PB has been so helpful so far and this is the first time he has told me something that didn’t match my research. I just replied to KimKat saying he followed up saying plaster rep said do nothing for 62 hours which takes us to Monday when the PB was planning to be back on site
bmoreswim
Platinum Supporter
6,441
Central MD
What you do depends on what your relationship with your PB is. Is he running the startup to ensure that his warranty is in effect? If so, you have little choice, except that you can always share your concerns and sources. If he is not calling the shots, I’d follow the NPC Card in this link.
https://www.nptpool.com/pdf/npc_swimmingpoolstart-upprocedures.pdf
Reactions: MikeFL and kimkats
MikeFL
117
Gulf Breeze, FL
I’ll
Thanks for the info, I sent PDF to the PB along with 10 other articles all with same recommendation. I asked him to have his plaster guy provide data or articles documenting benefit of waiting 72 hours.
panic_button
163
Panhandle Florida
Good luck, I will promise that you will not seen anyone on Monday. It took them 8 days to show back up after ours was filled and the water was starting to turn green...
Who did the plaster Moses' team? Do as they say, it's their baby until they sign over all the warranty paperwork.
Reactions: MikeFL
