To all those that religiously check their FC level and are totally confident that you’ve got at least a 7.5% FC/CYA..
Do you bother checking for combined chlorine?
So how often have you found to have an elevated CC level, with the correct amount of FC?Truthfully, I do. It's just a habit as that is how I learned to do the FC/CC testing so it is ingrained in me.
Maddie
I’m the same as Maddie. I do it out of habit. To answer your question: almost never do I notice even a tinge of pink. I ride the high side of suggested FC levels and dose even hotter when I know I’ll have a heavy bather load just to make sure.So how often have you found to have an elevated CC level, with the correct amount of FC?
Ok, what do you run yours at?also never let FC get anywhere near as low as 7.5% of CYA
I keep it between 10 & 20%, but closer to above 15% most of the time. I reduce the SWG by a couple/few points as FC reaches 20% or increase it a tad if it heads towards 15%, generally pretty much follows as the hours of daylight change seasonally (i.e., I don’t have to mess with it very often at all). Just makes it a little easier for me — never have to really worry much if an impromptu pool party or some other random something is going to cause a dip between testing. YMMV. Have never had anything other than sparkling crystal clear water (and want to keep it that way without thinking much about it ).Ok, what do you run yours at?
Chemistry follows predictable rules, and the better you understand those rules, the better you can manage the chemistry with fewer tests.
However, until you really understand the chemistry, you need to test more often.
If you are always able to predict what any test will be, then you are probably testing enough.
If you are ever surprised by a test result, you are probably not testing enough.
So what CYA level are you on?I keep it between 10 & 20%, but closer to above 15% most of the time.
Right now, about 50. For me at least, the CYA test is the most subjective so maybe it’s more like 60. I don’t think it’s 40. (I have the CYA 50 standard solution and that helps “calibrate” the eyeballs but it still has a subjective component to it). I aim for around 60 but we had a lot of rain with Ophelia, and this late in the season, no reason to bump it back up. But the subjectivity of the CYA test is maybe another reason (or excuse lol) to run FC a little higher than “necessary.” It doesn't cost me really anything in the grand scheme and makes things easier for me.So what CYA level are you on?
