- May 3, 2014
- 62,732
- Fiberglass
- Pentair Intellichlor IC-40
Going to zero during the day or losing more than 1-3ppm from morning to noon to night testing, once FC level is "established" with regular dosing.What would be too much FC fall off?
My suggestion is based on a 4-6hr testing window, (which would translate to 3-6+ppm for the day =8-12hrs)So, 2-4ppm FC fall off daily is typical (Mknauss), and too much FC fall loss is 1-3ppm on daily testing (splashpad) here is my current scenario.
1. AbsolutelyJust tested..
FC 7
CC 0
CYA 30
Pool TA 100 -Fill Water TA 70-
pH 8.0
I want to raise my CYA to 50. Should I do this by adding Dichlor?
I will test FC and pH daily and report those here.
Anything else you can think of?
So I know Muriatic Acid (MA) lowers pH, but it also lowers TA?Keep adjusting our pH to 7.6 when it gets to 8. Your TA will fall a bit. I suppose you get some of your fill water from the sky (rain). I believe your TA will settle about where your fill water TA is. But you will always have to add a bit of acid over time.
thank you splashpad for the added clarity- I get a lot of sun typically. Today it was 85*My suggestion is based on a 4-6hr testing window, (which would translate to 3-6+ppm for the day =8-12hrs)I should have noted that
1. Absolutely(use PoolMath to estimate how many/much to use)
2. It will let you learn/see how your pool trends, time of day is good to note
3. You are definitely headed in the right direction!
3a. Always undershoot when adding chemicals (any of them), just in case the reaction is stronger than expected.
Q: How much sun does your pool get? Cna you share a picture? ?
yes- over the pool- for sure.Each time you add MA, it consumes TA and lowers pH. Then through CO2 outgassing, your pH rises.
A measuring cup is a good idea. Just be careful. I pour it from the MA jug to the cup close to the water. So if I spill, it goes into the pool.
I will do that as well. I have it stored in the same place it leaked out, but now upright- and all the hinges are corroded..I store my MA in a 20 gallon Rubbermaid trash can with a lid outside, not near any metal. The fumes will corrode any metal nearby. Never store it in a confined space.
I would check with your store manager about requesting it.I will do that as well. I have it stored in the same place it leaked out, but now upright- and all the hinges are corroded..
Also where do you get your 10% Bleach? I saw that in your poolmath log
thank youI would check with your store manager about requesting it.
When you buy any liquid chlorine, it needs to be stored in the coolest/darkest spot you can. And preferably stored inside the store.
Check the printed date codes, get the freshest you can buy.
Also there might be pool supply stores near you, see if any of them carry Liquid Chlorine, Liquid Shock or Sodium Hypochlorite (the 'fancy' chemical name), the strength might be 10%-12.5%
thanks!Test you fill water's TA and lower the TA in your pool to around 50-60 That should slow your pH rise.
Keep your pH out of the 8's or you stand a good chance of seeing calcium scale in your pool.
thanks!
my fill water TA is 70, lower than my pool TA of 100.
just wondering, what do you recommend to lower the TA? Muriatic Acid?
