Can an expert point me in the correct direction to replace the motor in this pump? *pic*
citznfish
22
I can't seem to find an identical replacement and there are so many choices out there.
Per this thread, I think my motor is shot:
citznfish
22
Do you need that much horsepower?
Maybe consider going to a variable speed pump?
It is a 2 speed pump for my filter. 2 hp. 2.70 total hp. Pool was professionally built 3.5 years ago so I'm just replacing what they recommended. It also pushes water through a large 6 foot high waterfall.
JamesW
16,788
A two speed motor just has two speeds.
A variable speed motor can be set for any speed from about 600 rpm to 3450 rpm.
guinness
88
California
If you're going with a VS pump, then you'll need to stick to a Hayward pump like the Tristar VS or Ecostar to be able to control it with your OmniLogic controller.
citznfish
22
I just want to replace the motor, not the entire pump. Can that VS pump still work? I feel like I should just replace the motor with the same item.
JamesW
16,788
What about the motor that I linked to earlier?
It's listed as 2.6 hp vs. 2.7 hp for the Tristar.
However, in my opinion, the full rate Tristar hp is exaggerated.
