Pool pump no longer runs on low, and blows the circuit breaker when set to high
citznfish
22
Hello,
I have a Hayward (Century) 2 speed pool pump and an OmniLogic system to run all the equipment. I was in the backyard a few days ago and the pump ( on high) just shut off mid cycle, tripped the breaker at my pool sub, and ALSO tripped the main breaker at the house that powers all the pool equipment. In December I had replaced the coil so I thought it failed again. I replaced the coil this morning but the issue is still happening.
Pump on:
Low Volume: Nothing happens. No movement of the pump motor. no humming. no sounds at all.
Switch to High and *BAM!* heard a loud pop, see a flash at the back end of the motor, and the circuit breakers tripped at the pool sub panel and at the main breaker. this is repeatable.
All the wiring in the Omnilogic panel looks intact, nothing out of sorts.
Looking for ideas on what could cause these symptoms.
Pump Info:
Capacitor info:
TIA
CF
citznfish
22
Update:
Tried a known good breaker from my other pump..same results.
Opened the back of the motor up and didn't see anything shorted out or a dead lizard or anything that seemed to be amiss.
Tried to run the pump again, same result. No movement on LOW, on High it pops, i saw a spark come out the bottom of the pump, through the air vent.
I guess it's time for a new motor. Dang thing was only 3.5 years old.
danpik
1,725
western NY
Are all of the wires connected in the back of the motor when you have the cover off? The symptoms sound almost like a loose wire that fell across another terminal.
citznfish
22
Hi Danpik,
Everything was tight and connected properly. I checked all the connections to see if they were loose. Nothing seemed to be out of spec.
