Is there a good place to buy quality pool chemicals other than the local pool stores? The pool stores seem so expensive.
Thank you, I have read that before. I was wanting to know if there maybe a website or a cheaper store other than the local pool stores that people can buy quality chemicals from.In my signature below, you will find a link to "Pool School"....
Read it through.
We use the CHEAPEST/BEST methods of keeping a pool clean!
You may want to double check, Home Depot sells HDX muratic acid 31.45%, 2 gallons for $12.98. If you buy four cases it drops to $11.68 or $5.84 / gal.
HDX 1 Gal. Muriatic Acid Balancer (2-Pack) 10031HDX - The Home Depot
HDX 1 Gal. Muriatic Acid (2-Pack) is a powerful pH reducer for your swimming pool. It comes ready to use, with no pre-mixing required. This fast-working chemical helps prevent scaling caused by calcium-basedwww.homedepot.com
If available, you should buy Pool Shock at Menards before the end of this week as it is Buy One, Get One free through 7/6/19 and stronger concentrate than laundry bleach and less expensive.Just bought some bleach from Menards. Their “Solutions” brand is on sale right now for $2.49 and, although not listed on the bottle, this regular concentrated bleach is listed on their website as 8.25%.
I happened upon this thread while searching for CALCIUM CHLORIDE.My chemical list:
Cyanuric acid (Puri Tech brand on Amazon) $2/pound. STABILIZER
6% bleach (Walmart) $1.77/gal (prices vary by region) CHLORINE SOURCE
20 mule team borax (Walmart) $4.47/65 oz box. ph UP (and for for optional borate treatment)
Super washing soda (Walmart) $4.12/55 oz box. pH UP
Muriac acid (Lowes) $9.98. pH DOWN
Baking soda (Walmart) $0.50/lb. ALKALINITY UP
Snow Joe Melt calcium chloride pellet (Walmart online) $28/50 pounds (you might not need calcium, I have a heater and gelcoated fiberglass steps and need it). CALCIUM SOURCE
We need your signature completed.
@Steve_in_C (or anyone else) can you tell me the exact CALCIUM CHLORIDE to get? Wal-Mart has quite a few to choose from.... any suggestions? I need to add quite a bit according to PoolMath.
Thank you!
EXAMPLES
